Combined Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 03-14-2014, 10:33 PM   #1
jw1
Combined venting
I currently have a furnace running off natural gas which vents through the roof using PVC. Would it be possible to join a condensing tankless water heater which vents with PVC down stream about 10-15 ft and use a common exhaust.
I would rather have one exhaust vent running through the roof than two.
Both are power vented I believe.
Thanks!
The tankless is 199,000 BTU, not sure about the furnace.
jw1 is offline   Reply With Quote
Old 03-14-2014, 10:58 PM   #2
Rewards Points: 13,950
Most can be run out a wall.
I would not connect the vents.
ben's plumbing (03-15-2014)
Old 03-15-2014, 12:51 AM   #3
No, you cannot.
hvac benny is offline   Reply With Quote
The Following 2 Users Say Thank You to hvac benny For This Useful Post:
ben's plumbing (03-15-2014), hvactech126 (03-15-2014)
Old 03-15-2014, 02:17 AM   #4
jw1
Combined venting
Thanks!!!
Don't want to void the warranty either
Ridge Cap Venting Issues - Poor Ventilation?? askeyb Roofing/Siding 16 03-29-2016 04:05 PM
Venting ponch37300 Plumbing 41 02-23-2013 10:37 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
Gas furnace venting Qs (non high eff) WallyWoggle HVAC 6 12-09-2010 06:41 PM
Soffit venting vs. DCI Smart Vent JDPII Roofing/Siding 1 02-28-2009 08:42 PM
