combination forced hot air / central air problem
I have forced hot air / central ac in the house. I have a return under a closet which goes through the wall of my hallway and into the livingroom, it is floor level. All supply vents are 4" from the floor. I do not have a problem with my heat, the trouble is the ac. I have had it checked and all levels are fine. I had it cleaned and I have taken temps going into return is 75-76 and the supply is 50-55. I have pointed the ducts up to get the cold air as high as possible. Today it is 90 and the house will not go below 76.5. The space it is cooling is about 1100 sq feet. All rooms are vaulted to about 10- 11' Should I try temping the return duct high up to bring more heat into the system? Also just some more info the condensor is a Rheem 10 seer 2.5 ton unit. Thanks
