Combi Boiler Reset - HVAC - DIY Chatroom Home Improvement Forum
Old 07-20-2004, 01:47 AM   #1
Combi boiler reset
Hi there.
I'm wondering if someone might be able to help me out with a quick query. I had to remove a radiator from my bathroom however now that I've turned the water back on, the combi boiler does not start up - either for the central heating or hot water supply.
Is there something that I need to adjust/bleed etc?
imported_shane is offline   Reply With Quote
Old 08-10-2004, 05:21 PM   #2
Aussie Battler
Shane,
Did you drain the water heater?
imported_Alan is offline   Reply With Quote
Old 08-11-2004, 01:37 AM   #3
Yep.
I drained the system and removed the radiator. After doing what I needed to I replaced the radiator, filled the system and bled the radiators.
Still no luck.
Cheers
Shane
Old 08-13-2004, 05:14 PM   #4
Aussie Battler
Not an expert on this but I did drain a hotwater system once and she didn't fill up properly and within a few seconds she burnt out the element.
Old 08-13-2004, 09:14 PM   #5
Post
Is this a gas or oil fired boiler? Many of these units have a low water sensing probe. If it is a steam system (one pipe to radiators think it would be at the middle to down to about a third of the level and hot water (two pipe to radiators system) it would probably be at the top third. This probe is many times a single wire probe that can build up with minerals preventing the water to conduct for the sensing voltage (not alowing the unit fire up for safety). I used to work on industrial cooking equipment and some heating it has been years and I believe my memory on this is correct but if not I hope it can steer you in a possible right direction. If it has a probe and it is build up with deposits start with cleaning it rub it's length with somthing like a scotch bright pad until you see metal shining threw. get a least half the surface clean to metal and it should sense ok.
Good Luck
(DON'T BYPASS leval probes, if the boiler runs low on water it can go BOOM)
MgMopar is offline   Reply With Quote
Old 08-21-2004, 12:42 PM   #6
Check the water pressure (about 1 bar)
Check the overheat thermostat (hand book)
Check the pump turns (hand book)
dirkgently is offline   Reply With Quote
Old 12-29-2006, 06:24 AM   #7
did you bleed the pump when you bled rads.the pump is in the boiler has a big screw cover on the front of it open this when switched on put a screwdriver in and check its turning leave open for a few mins this will expell air from boiler then shut and see how you go
cheers
mox1968 is offline   Reply With Quote
