Old 09-27-2009, 03:16 PM   #1
Colemane Propane Furnace model#7956A856
Problem with burners. Pilot lite will stay lite, when burners come on it will shut all off in about 5-8secs
Anthonyj is offline   Reply With Quote
Old 09-27-2009, 03:51 PM   #2
GC/Master Plumber/Mech
Does this have an HSI ignition or an actual standing pilot?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-27-2009, 04:55 PM   #3
This has a Standing pilot.
Old 09-27-2009, 05:19 PM   #4
this has a standing pilot any help is needed
Old 09-28-2009, 12:42 PM   #5
Is this a mobile home furnace? Does the pilot go out also?
SKIP4661 is offline   Reply With Quote
Old 09-28-2009, 07:27 PM   #6
Yes this is a mobile home furnace and the pilot light goes out also
Old 09-29-2009, 02:25 PM   #7
You will need to check the roof jack (chimney). The center vent pipe may be rotted out. You need to take the cap off on the roof and check. If the center pipe is rotted it will cause the furnace to run out of oxygen and the flames will die in a few seconds, just like you explained. If it is bad, replacement roof jacks are available. Could also be a bee hive or birds.
Old 10-01-2009, 09:27 PM   #8
Thank You SKIP That was it !!!!
How do I convert my furnace from propane to NG? DGRAY HVAC 6 06-23-2009 07:11 PM
Furnace replacement and conversion from propane to NG. crblog HVAC 2 05-22-2009 04:57 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Cozy Propane Furnace Start up Noise NJ Gimo HVAC 7 01-01-2007 11:06 AM
