Coleman Presidential II Relay Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 06:02 PM   #1
Question
Coleman Presidential II relay issue
Hello,
I live in a mobile home and have a Coleman Presidential II gas furnace/air conditioner.
Recently, I've been having issues with the reversing relay (part #7670-308). I looked online for a direct replacement and now that I've installed the replacement relay (part #7670-3071), the unit will not shut off at all.
I thought it was due to a defective replacement relay so I ordered another and same thing, the unit keeps running.
Anyone here know what's going on???
How do I hook up the wires to this relay???
Much Thanx in Advance.
castleromeo is offline   Reply With Quote
Old 07-26-2013, 07:56 PM   #2
An old Tradesmen
Rewards Points: 7,376
A pic of the relays and where the wires are connected would probably help.
Old 07-26-2013, 10:39 PM   #3
OK, I took some pics. I took a pic of the schematic glued to the blower module. This is specific to the control panel which is at issue.
I also took some pics of the actual control panel and the relay I'm using.
Coleman Presidential II relay issue-7670-3071-relay.jpg   Coleman Presidential II relay issue-coleman-schematic.jpg   Coleman Presidential II relay issue-coleman-unit-1.jpg   Coleman Presidential II relay issue-coleman-unit-2.jpg   Coleman Presidential II relay issue-coleman-schematic-2.jpg
Old 07-27-2013, 04:38 AM   #4
An old Tradesmen
Does the fan run in low or high speed all the time.
That is a sequencer that you changed out, not the relay. The relay is to the left.
Old 07-27-2013, 05:40 PM   #5
The unit runs in high speed all the time. The sequencer is a type of relay.
Old 07-27-2013, 05:43 PM   #6
An old Tradesmen
Yes it is. So did you check the relay to the left of the sequencer.
Old 07-27-2013, 05:50 PM   #7
I replaced it recently. Both the old relay and the new relay have a diagram pasted on the side andthe terminals were numbered so it was easy to reattach the wires.
Old 07-27-2013, 05:54 PM   #8
An old Tradesmen
Sounds like you need to get out a multi meter and see what is causing what to send power to the blower constantly.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (07-27-2013)
Tags
coleman , hvac , presidential ii , relay
Relay on Heat Pump control box making clicking sounds berr3555 HVAC 8 02-22-2013 06:57 PM
Heating relay wiring Toledo Electrical 6 11-26-2009 12:03 PM
Wiring 220 and relay bohaiboy Electrical 7 11-19-2009 03:41 PM
Need a relay for off peak heat BorisMD Electrical 16 09-13-2009 05:25 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
