Coleman Gas Furnace/Air Conditioning Unit's Blower Won't Stop - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 07:46 PM   #1
Coleman Gas Furnace/Air Conditioning unit's blower won't stop
Good day,
I have a Coleman/York furnace/air conditioning unit (model is TG9S*MP). The air conditioning is working fine, kicking in according to the thermostat, but the blower won't stop even when the thermostat is at off. What is making the blower running continuously ?
Thanks,
JP
MarchandDeBoeuf is offline   Reply With Quote
Old 07-18-2012, 08:19 PM   #2
Rewards Points: 460
Check if thermostat has a FAN switch or setting. Switch off if it is on. Otherwise the green wire to thermostat may be on wrong terminal.
diyorpay is offline   Reply With Quote
Old 07-18-2012, 09:44 PM   #3
The thermostat as option On or Auto for the fan and the green wire inside the thermostat is not connected at all. It was working fine before and I didn't made any changes before it started doing that.
Thanks,
JP
Old 07-19-2012, 06:45 AM   #4
Some furnaces will turn the fan on continuously if there is a problem with the furnace (like a tripped vent switch, or a faulty control board). Assuming you're not running the heat, I'd hazard a guess that you have some issues with the board on the furnace, and that's not really something that you can troubleshoot.
Odd that the G wire isn't hooked up, unless you have some sort of communicating thermostat ...
scottmcd9999 is offline   Reply With Quote
Old 07-19-2012, 03:19 PM   #5
Yes, it's also my guess that's there's something with the board or another sensor in there. Thanks
JP
carrier furnace...no heat blower won't stop kevinp HVAC 19 11-13-2014 11:37 PM
New Coleman oil furnace, won't stop running Loni HVAC 11 10-16-2010 07:40 PM
Stop Whining Blower vdu HVAC 38 08-09-2010 10:27 PM
New furnace & air conditioning units mcips HVAC 3 06-15-2010 11:27 PM
RPJ2 Blower fan will not stop running number22 HVAC 8 07-19-2009 06:27 PM
