Coleman Furnace Problems - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 09:50 PM   #31
IUFAN87 is offline   Reply With Quote
Old 01-01-2012, 12:52 PM   #32
AKA HVACTECHFW
Rewards Points: 1,208
your picture is of a fresh air damper. DO you see your gas valve on your furnace? Look to the right of there, maybe a little up, there should be another motor. If not then you have a standing pilot system. Can you post a picture of the whole furnace if you cant find or dont understand what I'm talking about?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-01-2012, 01:22 PM   #33
Old 01-01-2012, 01:35 PM   #34
AKA HVACTECHFW
the motor on the right side of the furnace to the right of the control board with 2 black and 2 blue wires going to it is the draft motor.
IT IS WHAT IT IS
Old 01-03-2012, 05:57 PM   #35
Ok, Ive done some more troubleshooting. I cleaned a BUNCH of dirt (15 years worth) off the A coil. It seems to flow air much better now. Im thinkin that could be a reason for some of the intermittent, code 4 limit cycling codes. The furnace ran flawlessly last night and all day today. Then just all of a sudden I got the rapid flashing trouble code LED again. The temp was up in the house and the t-stat wasnt even calling for heat. This rapid flashing LED really has me baffled. It seems to do it about the same time every day. Sometimes it will reset by cycling the power switch and sometimes it wont.
Old 01-04-2012, 07:47 AM   #36
sleepyg's Avatar
Rewards Points: 26
You say it happens the about the same time every day, what is happing at the time you get the rapid flash? If you are getting spikes in the power then that can really confuse some electronics!
sleepyg is offline   Reply With Quote
Old 01-04-2012, 07:56 AM   #37
Nothing is happening out of the ordinary as far as i know. Im fixing the problem though. Called my hvac guy and ive got a new 95% efficiency furnace on the way. Sure hope its not a voltage spike from an outside source. I wanted to get a different brand of furnace besides coleman. But apparently, since its a manufactured home, coleman is bout my only choice.
Brand new Coleman 97.5% furnace makes horrible whining noise junebuggy HVAC 10 11-15-2016 09:53 AM
Lennox ghr26 furnace problems wayfis HVAC 8 01-05-2010 05:51 PM
coleman mobile home furnace smurfette HVAC 2 11-01-2009 08:10 PM
hiel furnace problems plumbfitter HVAC 5 08-31-2009 09:54 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
