Coleman Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2007, 10:47 AM   #1
coleman furnace
Our Coleman furnace is making a grinding noise or squeal during start up. It stops once the main blower energizes. Can you give us any advice?
mrsv118 is offline   Reply With Quote
Old 12-02-2007, 03:39 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,906
coleman furnace
If this is a high efficency gas furnace, it could be the blower bearings for the combustion chamber going bad.
gregzoll is online now   Reply With Quote
Old 12-02-2007, 08:33 PM   #3
Send a message via Yahoo to mrkool
coleman furnace
Yeap, it's the venter/flue gas motor, usually if it's already making a noise,
it won't last much longer, a lot of the newer motor are sealed from any further lubrication, but you can try to get some 10w-30 oil into each end of the shaft where the bearings are located, might buy you a week or 2.
I have several good used and new venter motors in my shop that might work I can give you a deal on, better than sending them to the scrap yard.
mrkool is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 02:27 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
