Coleman Evcon Short Cycling - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 09:30 AM   #1
Post
coleman evcon blower problem
I have a coleman / evcon 2703-341 model BGUO7512A that will turn on, burners on, heat up and then shut down. Led flashes 4 times which is limit fault code. I assumed hi limit switch fault but upon further investigation found that the blower is staying on low speed which I figured would cause the heat exchanger to overheat and shut the furnace down. Once cooled down it fires up and repeats the process. I checked the A-coil and it is spotless. I removed the blower fan and it too is clean. Any suggestions on how to check if the motor is ok or if it's the board. Several years ago I had to change a relay on the board, that controled the motor, due to a burned out coil. is there another relay on the board that controls speed?
Thank you.
Also, I have been told that intermittently it did/does blow on a higher speed, but only occasionally
AEROFANZ is offline   Reply With Quote
Old 12-09-2010, 02:40 PM   #2
Problem Solved
After checking the board and the capacitor I determined that the motor was at fault. It would run on slow speed no matter which lead was powered up. Now to find a place to buy a replacement that won't try to rip me off or demand that I show them a gas licence for and electrical component....go figure.
Steam boiler is short cycling rjpriester HVAC 8 05-16-2010 08:53 AM
Goodman & Honeywell Vision Pro Short Cycling tpirovol HVAC 8 12-23-2009 05:55 PM
Problem with Burnham Oil Furnace short cycling Catherine M Brown HVAC 13 01-29-2009 10:58 AM
Furnace short cycling stubborn1 HVAC 2 12-08-2008 11:46 AM
HVAC Short Cycling Redparis HVAC 2 02-26-2008 10:21 PM
