Old 05-17-2012, 05:18 PM   #1
Coleman evcon eb20b no heat or /ac
I have a coleman evcon eb20b and all the sudden no heat or ac
i looked at tstat (honeywell chronotherm III) and no lights are on but cant remember if they only came on when in operation.
things ive done
replaced batteries in t-stat
checked fan ,heat and ac by crossing red and green, red and white etc and got nothing
tested for 24v at t-stat red and blue (common) nothing (checked all wires actually)
opened up heater traced where red and blue wires connect to other wires took off wirenuts ant tested there and nothing
what do i check next transformer? if so what peg or pegs to i check ... i got 240 going in but which ones for 24v out?
thanks for you help
handyman555
handyman555 is offline   Reply With Quote
Old 05-17-2012, 10:57 PM   #2
I'm Your Huckleberry
The wires on the other side of the 240 (120?) going into the transformer going out will be 24 out. It should state on the transformer which wires are 24 volts.
Thanks.
Doc Holliday is online now   Reply With Quote
Old 05-18-2012, 02:56 AM   #3
since you are not getting 24v from R and C, your board doesn't have power. Test transformer like Doc said above, also while you are there check the 3 amp fuse, make sure it's good. Actually did you check to make sure you have 120v going into the furnace? Try to plug a light into the furnace's outlet to see if you have power
Mr.HVAC is offline   Reply With Quote
Old 05-18-2012, 05:41 AM   #4
An old Tradesmen
On Evcons usually a red and black coming off the transformer for your 24 volts. The red on some have a 3 amp fuse. Depends on when it was made.
Old 05-18-2012, 03:32 PM   #5
it looks like i am getting nothing on the side that says load (red and blk wires) i am getting 247v on line side of transformer and getting 247 or 123v every other way .... also have no plug in to test on my coleman unit
thanks again guys
Old 05-18-2012, 04:17 PM   #6
An old Tradesmen
Might want to look for a short before you just put another transformer in it.
Old 05-18-2012, 04:44 PM   #7
it looks like i got 240 v going in just not 24 comming out.....look for short where?... shouldnt there be 24v comming out of the load side of transformer sorry im a carpenter not an electrician so bare with me
Old 05-18-2012, 05:10 PM   #8
If you do not have 24-ish volts coming out than the transformer is 100% kapoOt.
Be forewarned, once in a blue moon Pale Ale , a transformer will simply go out. 9 of 10 times an electrical issue such as a backfeed or short somewhere caused the transformer to blow. You will know once you install a new transformer.
Thanks.
Old 05-18-2012, 05:15 PM   #9
Check all control wiring to see if anything anywhere has lost it's insulation and is touching metal cabinet or another wire.
Thanks.
Old 05-18-2012, 11:02 PM   #10
I bought a transformer with built in fuse so if there is short it won't blow my transformer .. There is no fuse on this unit... Will check all wires tho
Thanks again
Old 05-18-2012, 11:04 PM   #11
Thanks again
Good choice! If there is no fuse than it's going to be a short on the low voltage side, such as beenthere previously said. Had it been on the high voltage lines the breaker(s) would have tripped in your home's electrical service panel, most likely.
Let us know if the fuse blows and on what call, fan on , heat or cool. Actually, best bet would be to try heat first and then fan on. If your transformer blew while on call for cool than it could be outside at the condenser.
Check cooling last.
Thanks.
Old 05-19-2012, 07:40 PM   #12
that seemed to do the trick .. just a bad Transformer... i want to thank Doc Holliday,Beenthere and MR.HVAC for all your help... couldnt have done it with out you!!
what a great forum!
thanks again
Handyman555
The Following User Says Thank You to handyman555 For This Useful Post:
Doc Holliday (05-19-2012)
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Coleman Evcon DGAT056BDC cnobin HVAC 2 11-17-2010 05:38 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
