Coleman Evcon DGAT056BDC - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 02:15 PM   #1
I recently replaced an exhaust motor with a X89-684 BST Motor and didn't label my wires or connections. In turn, it burnt out the board for the ignition module when I thought I had wired it properly. I replaced the ignition module and it is wired up correctly. I am 99% sure that I had connected the wires from the motor to the wrong contacts on the same relay in the upper part of the unit. My question is about the motor. It has two black wires and two blue. What are the proper connections before I turn it on and blow another board?
cnobin is offline   Reply With Quote
Old 11-17-2010, 05:24 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
black wires should be hot and common to power motor, blue wires should be centrifugal switch on bottom of draft motor to prove motor is working before allowing ignition
hvactech126 is offline   Reply With Quote
Old 11-17-2010, 05:38 PM   #3
An old Tradesmen
Rewards Points: 6,464
I think that furnace is under a recall.
Might want to find out before you spend more money on it. It may have a cracked heat exchanger.
Brand new Coleman 97.5% furnace makes horrible whining noise junebuggy HVAC 10 11-15-2016 10:53 AM
Coleman 3300-378 Thermostat deMad10 HVAC 0 12-30-2009 06:16 PM
coleman mobile home furnace smurfette HVAC 2 11-01-2009 09:10 PM
coleman furnace mrsv118 HVAC 2 12-02-2007 08:33 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
