Coleman Evacon Furnace Inducer Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 01:44 AM   #1
Unhappy
When we originally turned on the furnace this year the fan was not working. The tech that came out freed up the fan and cleaned it. He said it may have been stuck due to sitting for the summer and condensation. So now it seems to work ... sometimes. Then all of a sudden the motor will just stop and the furnace will not turn on again. We get the 3 flashing lights as we were getting originally.
If we wait until the lights stop flashing or turn off the furnace manually and turn it back on calling for heat the only way the inducer fan starts is if we hit the outside of the fan container to jar it. It will then go through normal cycles but will eventually repeat this scenario over again. We probably can replace the inducer fan motor but can you oil or lubricate the fan motor? If you can what is best to oil it with? 3 in 1 oil, WD40???
Melleric is offline   Reply With Quote
Old 10-17-2013, 06:15 AM   #2
An old Tradesmen
Rewards Points: 6,148
Time to replace it. It will just seize up again sometime later if you manage to lubricate it. And if it does it on a cold Sunday, you could be without heat for a day or 2, and risk frozen water pipes.
The Following User Says Thank You to beenthere For This Useful Post:
Melleric (10-17-2013)
Old 10-17-2013, 08:40 AM   #3
Rewards Points: 154
inducer
And go ahead and order the entire inducer assembly, not just the motor. It sounds to me as if the squirell cage is hanging up. It may be worth it to remove the assembly and take a look at the blower wheel.
Patrick Eubanks is offline   Reply With Quote
The Following User Says Thank You to Patrick Eubanks For This Useful Post:
Old 10-17-2013, 11:45 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,158
Usually we replace the whole fan unit with motor and wheel. 99.9% of the time the wheel won't come off or it gets warped and ruined. Only brand I know that sells the motor separate is Carrier and I always get the wheel with it.
The Following User Says Thank You to yuri For This Useful Post:
Inducer motor replacement on a payne furnace exintrovert HVAC 6 07-02-2010 08:07 PM
Replacing Fasco 7062-3136 draft inducer blower on my Bryant Gas Furnace thalweg76 HVAC 0 02-20-2010 04:35 PM
payne furnace inducer motor minime_moomey HVAC 13 02-20-2010 01:52 PM
coleman mobile home furnace smurfette HVAC 2 11-01-2009 09:10 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
