Coleman Echelon 8.C Furnace Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 10:54 PM   #1
Coleman Echelon 8.C furnace issue
I have a Coleman Echelon 8.C model CP8C100C16MP11 and it is only putting out cold air. I checked the LEDs on the ckt bord; it shows the following: Green, steady flashing indicating normal operation. Yellow, flashing twice indicating a demand for heat. I checked the igniter and it is cold. Is there anything else I should check, & can I order a replacement part or do I have to go through a repair serviceman?
PNWrider is offline   Reply With Quote
Old 02-28-2013, 05:32 AM   #2
An old Tradesmen
Rewards Points: 6,458
Pretty much all parts on it should still be in warranty. And only dealer can get warranty parts.
You should get an error code, not just a heat call flash.
Tags
coleman , furnace
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Gas Furnace fails only at night - pressure issue? Ken321 HVAC 5 04-15-2012 08:37 PM
Ruud Furnace issue grubslinger HVAC 16 09-14-2011 01:13 AM
Coleman Echelon 9V - high fan speed in low stage?? Car Guy HVAC 7 12-03-2010 03:28 PM
New Coleman oil furnace, won't stop running Loni HVAC 11 10-16-2010 07:40 PM
