Cold Room - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2007, 02:12 PM   #1
Rewards Points: 14
Cold Room
Hello, any suggestions on the best way to increase airflow in one room. My bedroom is the furthest away from the heater, and doesn't seem to get enough airflow. Most of the other rooms in the house are good, but this room just does not get warm enough. If I turn up my thermostat to make that room warm enough, the rest of the house is way too hot. I have a gas forced air through ducts.
msajeep is offline   Reply With Quote
Old 11-13-2007, 03:07 PM   #2
Rewards Points: 150
Most registers have adjustable baffles. Close up the registers in other rooms a bit, and open them in this room wide open.
scorrpio is offline   Reply With Quote
Old 11-13-2007, 06:51 PM   #3
Rewards Points: 14
That has been tried and didn't do much, any other thoughts or products that can help?
Old 11-13-2007, 07:24 PM   #4
hi
I believe they make small fans....called "boosters" that fit inside the ductwork wired to the furnace going to that paticular room. That will increase the airflow in that room a lot.
nikko4 is offline   Reply With Quote
Old 11-13-2007, 08:24 PM   #5
no loose ends
Dampers suck
Nikko4 has the right idea. What I've done in these situations though, is use a timer to allow the booster to run during the day time. Or, because most boosters draw such low amps, it wouldn't hurt to let it run all the time. This will cause a "mixing" effect; Air is drawn into the boosted duct from all ducts creating more of a balance throughout.
undone is offline   Reply With Quote
Old 11-13-2007, 10:26 PM   #6
Firefighter/Paramedic
tyler101's Avatar
Here are a couple different options. http://www.espenergy.com/booster_fans.htm
tyler101 is offline   Reply With Quote
Old 11-14-2007, 07:21 AM   #7
Rewards Points: 14
Thanks for the replies, that seems like a good idea. Here's my question, where does this have to be placed in the duct? The problem is, that I have finshed and drywalled my basement , so I don't have access to the duct from below, only from right in the room.
Cold room above garage, Asbestos? Crackers Building & Construction 1 09-09-2007 10:35 AM
What is cold room for? KUIPORNG Remodeling 4 04-26-2007 06:06 PM
My kids room is cold snmhanson HVAC 5 12-20-2006 12:51 PM
Adding a vent in cold room... AllGoNoShow HVAC 1 11-21-2006 12:16 PM
