Cold Return Relocation - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2008, 11:53 AM   #1
cold return relocation
Hi all, new to this forum and looking for some advice.
I am moving a wall to expand a 2nd floor bathroom and the wall coming out has a cold air return in it. Where the wall is located will be open floor space, could I put a floor grill on over the return and leave it as is or do I need to relocate to another wall?
Thanks for any help...
mfwhite22 is offline   Reply With Quote
Old 01-21-2008, 12:28 PM   #2
don't know if I understand your question... but certainly not want to open inside the bath room consider all the smells....instead have it open to the open space instead.... ours is at the close to ceiling level in the wall in 2nd floor.... I heard that is the correct location rather than near the floor.
KUIPORNG is offline   Reply With Quote
Old 01-21-2008, 02:51 PM   #3
The return is right now at the top of the wall we are removing. I did not think of the oder issue but that is a good point....I may go ahead and get an HVAC person to look at what can be done to make this work right...
Old 01-21-2008, 03:00 PM   #4
if it exists before then may be it is ok... as may be everyroom should have a return air.... in order for the air to be able to circulate.... I would follow the "don't change it if it is not breaks" rule instead in this case...
Old 01-22-2008, 06:08 PM   #5
Union HVAC Tech.
It is easy enough to move a return. You don't want to pull air from a bathroom, ever. Can you use the floor bay that it is currently in and just go to the next wall and cut out the plate?
bigMikeB is offline   Reply With Quote
Running network wiring in a cold air return vent? mcvane Electrical 26 04-19-2007 08:52 AM
What size should cold air return grille be? AllGoNoShow HVAC 1 02-27-2007 04:48 PM
Repositioning cold air return bgefire HVAC 1 11-19-2006 02:01 PM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 11:54 PM
