Old 02-24-2011, 08:02 PM   #1
cold return and heat vents in basement
I am finishing my basement and have come to the heating portion of the project. The room is 25x17 there is a cold air return in the center of the room coming out of the ceiling. Should I move this to the floor or can I leave it be? And what size run and grille should I use? If I do move it can I place it on one end of the room or should it be in the center of the room? And second will two supplies be sufficient if I put one above each window? Any ideas would be greatly appreciated.
gaetz1 is offline   Reply With Quote
Old 02-24-2011, 08:56 PM   #2
An old Tradesmen
If the supplies you use throw the air to the floor, then the return can remain in the ceiling.
2 supplies may be enough, depending what size they are.
Moving heat from wood stove in basement Mike in MN HVAC 0 11-23-2010 12:04 PM
Oversized Furnace, Undersized Return Air vents and Low Heat Output.... ?? LabRat0116 HVAC 4 10-04-2010 09:53 PM
Remodeling Basement.. Have Heat vent/return air questions. CycloneBrian HVAC 7 02-06-2010 06:15 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 02:44 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 01:43 AM
