Cold In Ohio - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 10:00 PM   #1
cold in ohio
thank you for your help. i have a armstrong furnace model eg6g100dc13-2. i turn the furnace on the combustion blower comes on but it does not inite.i let it run for 10 minutes an then i have to turn the thomostat or the switch on the side of the furance on an off , on an off real fast for about 3 minutes an it inites.it works good for about an hour or 2. i turn the thomostat down because its to hot for about 20 munite .an then i have to go through the whole process again. help
bulleye is offline   Reply With Quote
Old 12-21-2010, 03:06 AM   #2
The firs thing I hope you did was make sure your filter is new.
As far as what you are describing it could be a sensor or a smart valve.
The sensor can be cleaned ith fine steel wool.
I am chcking the model to se if it is a smart valve.
hvaclover is offline   Reply With Quote
Old 12-21-2010, 03:02 PM   #3
cold in ohio
thank you for your reply. i put a new flame sensor an pilot part an ingintor on an it did the same thing. would the tramsformer/relay or combustion blower relay be bad. thanks
Old 12-21-2010, 03:21 PM   #4
If you have a Smart valve that is what the problem is.
[IMG]file:///C:/DOCUME%7E1/John/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]Is this the type of igniter and sensor?if it is you need this
Old 12-22-2010, 11:21 AM   #5
cold in ohio
my sensor does not have the long fork metal on it.an i dont have a smart valve. am lost.
Old 12-25-2010, 12:04 PM   #6
cold in ohio
i hope you have some other ideas. thanks
Old 12-25-2010, 12:13 PM   #7
Experienced
Jackofall1's Avatar
Do you have an electrical meter and are you confident enough to attempt some trouble shooting?
You sure of that model #? Doesn't seem to jive with Armstrong numbering system.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
