Cold House.... - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 10:01 PM   #1
cold house....
luxaire model pdu-id08n080a
older model maybe 18 years old
don't have draft inducer fan
Okay so this is my problem, I had to turn the thermostat off/on in the past two days, now nothing. The furnace will only make a light relay sound when I turn power off/on. nothing more, no fan, no hot surface glow, no gas release..nothing. I cleaned the flame sensor and the pilot ignitor. Thank goodness I have a few electic ceramic heaters from camping, sure is cold in buffalo area tonight! Thanks for any insight I might get........
just trying is offline   Reply With Quote
Old 01-27-2009, 05:27 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Check for power to the draft inducer, if it's getting power and not working, replace it. This is the first thing that's supposed to happen in the sequence. If it's not working, then nothing else will.
wirenut1110 is offline   Reply With Quote
Old 01-27-2009, 08:51 AM   #3
I think it is whats called Natural draft furnace, no motor. It does have a hot surface pilot.
Old 01-27-2009, 08:54 AM   #4
JohnH1's Avatar
Do you have a/c you may have a 2nd switch on the t-stat. Switch it to fan on to see if the fan runs and check if you have power to the furnace. Lets start with the basics.
JohnH1 is offline   Reply With Quote
Old 01-27-2009, 09:10 AM   #5
Rewards Points: 510
After rereading ita couple times, I see that now
Old 01-27-2009, 09:33 AM   #6
no a/c, but the first thing I think that suppost to happen is the "buz" box sends signal to "spark plug" to spark. It does not spark or even try so I guess I need to start with what is it that sends the spark to the spark plug ignitor thing?
Old 01-27-2009, 09:52 AM   #7
JohnH1's Avatar
You sead you have hot surfice ignition. Now you say spark. Which is it? Are you sure you have power at the unit this is the 1st thing to check.
Old 01-27-2009, 10:24 AM   #8
Sorry I was wrong. I have looked in images this is what the furnace has... for sure: Pilot Igniter/Burner Assm W/Flame Rod & Spark Igniter Single Tip. So I am going to figure out how to replace this and start there. I have a meter but need to be walked through what to /where to check. Thanks for looking into this...........
Old 01-27-2009, 10:34 AM   #9
JohnH1's Avatar
I am going to assume you have checked for power and that you have it. We can not seem to get this question answered. So assuming you have high voltage you need to see if you have power at you ignition modual. If you can tell us the model of the modual we can probly tell you what terminals to check. You can follow the spark cable back to the modual.
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Cold Air Return in an Old House DaleB HVAC 2 01-09-2009 10:20 AM
Hello. I moved my house... shtoink Introductions 10 06-25-2008 01:40 PM
"New: House, and need some advise... dcd22 General DIY Discussions 9 06-17-2008 07:12 AM
Re-siding house jdig Building & Construction 5 04-10-2007 09:15 AM
