Cold Heat Pump Compressor Means What - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2009, 11:51 AM   #1
walt1122
Rewards Points: 334
cold Heat Pump compressor means what
Hi, I remember someone once saying that the "rule of thumb" for Heat Pump compressors is that they should be body temperature or slightly warm to the touch after they have been running for awhile. I have a geothermal unit and the compressor is cold to the touch. Means it is over-charged? right?? I know this is an oversimplification of the problem but am I on the right track.
thanks
Walt
walt1122 is offline   Reply With Quote
Old 10-14-2009, 02:51 PM   #2
thanks
Walt
The only "rule of thumb" in HP diagnostics is that there is no "rule of thumb". Many different data points need to be analized and only then will they lead you down the right path on your journey to finding root cause.
hennyh is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Installing natural gas furnace in place of heat pump, please help KlamathMog HVAC 17 10-20-2009 01:55 PM
Heat Pump set back GEAF HVAC 6 01-26-2009 07:49 AM
Wiring a RobertShaw 9870i to Gas Furnace & Heat Pump jerfer HVAC 11 12-21-2008 09:09 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
