Old 02-13-2008, 05:09 PM   #1
COLD fireplace
We've recently moved into a two-story home that's 5 years old. The living room (which has a gas fireplace on the main floor) is COLD! The thermostat to the house is in that room, so our furnace continues to run, which is making our upstairs at least 10 degrees warmer. We thought the gas fireplace was bringing in all the cold air, or pulling out all the hot air so we looked for a flue or damper to close - no luck. We have it sealed off with plastic right now, which has helped some, but our main floor is still cold. Any ideas? We've checked the windows and doors and everything seems to be sealed up. It's noticeably colder next to the cold air return duct, is that normal?
Ging is offline   Reply With Quote
Old 02-13-2008, 07:12 PM   #2
Eibwen
COLD fireplace
If your ductwork runs thru an unheated space such as an attic, it could be underinuslated or have some leaks.
Sammy is offline   Reply With Quote
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 09:10 PM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
Fireplace leaking mmcginn2 Roofing 4 04-23-2006 11:12 AM
