#1 |
Cold in Colorado
Hi all,
I'm having slightly different problems with my Bryant 383KAV than the following thread: Bryant 383kav What I've tried. We had a fault 34, we unplugged the HSI and tested continuity. It had an open loop, so we removed it and saw a hairline fracture. We replaced it and it still wouldn't work. We noticed the fuse was out on the board and replaced it. Upon start up it blew again. I unplugged PL1 and turned it on and the fuse was fine. So I unplugged each of the components on the other end of the wire hardness, and repluged in PL1. The fuse blew on the last components I installed, which was pins 1 and 7, going to three switches. Removing the wiring from the switches I have continuity through all of them, all are NC. With PL1 installed I have continuity from pins 1 and 7 to ground, with the plug removed it don't. It seems likea board issue, but I followed the traces and they seem fine. No clear evidence of failure, but that may not be the case. Please let me know if I should try something else before ording the board. Thanks. |
#2 |
I'm Your Huckleberry
Cold in Colorado
I'd have to think it's one of those switches that went bad.
Thanks. |
| Tags |
bryant gas furnace, fault code 34, heater ![]() |
| Display Modes | |
| Kenmore 596 bottom freezer cold top warm | klimshelf | HVAC | 2 | 03-30-2011 09:32 AM |
| Adding on to cold air return | agicr | HVAC | 13 | 03-27-2011 02:33 PM |
| Freezing storage room next to the cold room | Van3 | Building & Construction | 2 | 01-23-2011 06:50 PM |
| Backdraft, Cold Air and Ice from Range Hood and Bath Fan | Passion4Heels | HVAC | 13 | 08-19-2010 08:00 PM |
| No Cold Water at all - both cold and hot pipes are burning to the touch | bluecifer | Plumbing | 12 | 01-19-2009 11:29 AM |
