-   -   Cold in Colorado (http://www.diychatroom.com/f17/cold-colorado-163410/)
MntClimber 11-15-2012 08:54 AM
Cold in Colorado
Hi all,
I'm having slightly different problems with my Bryant 383KAV than the following thread:
http://www.diychatroom.com/f17/bryant-383kav-161362/
What I've tried.
We had a fault 34, we unplugged the HSI and tested continuity. It had an open loop, so we removed it and saw a hairline fracture. We replaced it and it still wouldn't work. We noticed the fuse was out on the board and replaced it. Upon start up it blew again. I unplugged PL1 and turned it on and the fuse was fine. So I unplugged each of the components on the other end of the wire hardness, and repluged in PL1. The fuse blew on the last components I installed, which was pins 1 and 7, going to three switches. Removing the wiring from the switches I have continuity through all of them, all are NC. With PL1 installed I have continuity from pins 1 and 7 to ground, with the plug removed it don't. It seems likea board issue, but I followed the traces and they seem fine. No clear evidence of failure, but that may not be the case.
Please let me know if I should try something else before ording the board. Thanks.
Doc Holliday 11-15-2012 10:40 AM
I'd have to think it's one of those switches that went bad.
