Cold Bedrooms - HVAC - DIY Chatroom Home Improvement Forum
Old 12-25-2008, 09:09 PM   #1
Jimbo41042
Smile
Cold bedrooms
We have a small house but our bedrooms have to be open in order for the rooms to access cold air return in our hallway , my question is should i put cold air returns in each bedroom or maybe just saw an inch off of the bedroom doors ? I am unsure what to try .
Jimbo41042 is offline   Reply With Quote
Old 12-25-2008, 11:21 PM   #2
Well either way would work. I personally have returns in each of the bedrooms. But its much harder to do that then to cut the doors.
So easy way would be to cut the doors, but both will work.
integlikewhoa is offline   Reply With Quote
Old 12-26-2008, 05:57 AM   #3
An old Tradesmen
Rewards Points: 6,550
Do you want privacy when Your bedroom door is closed.
If so, under cutting the door is not the right way.
It will work, but you won't have privacy any more.
Cutting a low grille in teh bedroom, and a high grille in the hall way, will give more privacy then cutting the doors.
Old 12-26-2008, 12:48 PM   #4
Jimbo41042
Cold bedrooms
Yep the privacy of us the parents and our daughter plus we have dogs running around ( I think i will try putting a cold air return in the 2 rooms ) thanks
Old 12-26-2008, 01:09 PM   #5
I can see it now, a few dog noses and a pair of eyes (your daughters) suck in the 1" gap under the door.
Daddy what u doing?
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 01:43 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
