-   -   Cold air returns, or transfer ducts/grills? (http://www.diychatroom.com/f17/cold-air-returns-transfer-ducts-grills-167915/)
bobgodd 01-01-2013 01:11 AM
Hello. I have one room, my master bedroom, that is ridiculously cold compared to the rest of the house. My wife and I just purchased the home (first home) two months ago, and the weather was still warm in Southern California at the time. While it doesn't get too cold here, there were a couple occasions where we did not leave the heater on at night and our bedroom was on the 40s!!
So in my quest to figure out why my bedroom was so cold, we've stumbled across a few issues that will need addressing. There is no window, only one sliding patio door that had a huge crack in it. I sealed it up with caulking as a temp fix but we're replacing that door shortly. Another thing I stumbled across was that my forced air heating system might not be as efficient as possible. If it comes down to an issue of a little bit of ducting work and some elbow grease, I have no issue going a little extra mile to make it as efficient as possible.
The furnace is in a cabinet in the hallway, and there is only one cold air return and it is directly below the furnace cabinet in the hallway. I've read that my bedrooms might not be cooling properly because we leave the doors closed at night time and there is no cold air return inside the room, which causes the heat register to not be able to force air properly. Some solutions to this that I've found in my [brief] research were to place cold air returns in each room, or to install transfer ducts/grills in the attic - since that's where my current ducting is.
So my question is, within the scope of obvious/non obvious limitations, which would help make my system as efficient as possible? All of the heat registers are in the ceiling, and within a few feet of the openings of all the rooms. If I were to install cold air returns, they would have to be in the ceiling as well; is that going to help, or is that counter-intuitive? Please advise!
Rob
http://i23.photobucket.com/albums/b3...ps6a0316c7.jpg
beenthere 01-01-2013 06:35 AM
If you move the supplies toward the outside walls and hen use the existing hole for your transfer grille, you should get the result you want.
joecaption 01-01-2013 09:51 AM
Those ducts where suppost to be "washing" air across all the windows. Right now the cold air coming in the windows is just droping to the floor and cooling the whole room.
Is there a about a 1" gap under the doors? It's needed so the air can be sucked out of the room at the floor level and into the cold air return.
Is that garage wall insulated and sheetrocked with 5/8 sheetrock?
bobinphx 01-01-2013 10:58 AM
I had similar issues a couple of years ago! I put in transfer ducts, solved the issue. Additionally, while researching hvac I also found lots of other issues. My systems static pressure was way high (1.5 Iwc). I found that replacing the plenum box, removing almost all flex, adding a second return grill and doubling the return duct and finally using 4 inch merv 11 media filters fixed the problems!!!!!!! So I just wanted to say, it is possible to fix your issues. Comfort was the biggest benefit, but a 25 percent decrease in my electric bill was great too!!!!
Fix'n it 01-01-2013 12:16 PM
is the room ok when the door is left open ?
bobgodd 01-01-2013 01:53 PM
Thanks for the replies everyone!
Are you saying that I would use the existing location (after relocating the supply) as a transfer grill, or as a cold air return? My understanding of the differences between the two is a bit limited.
There is about a 1" gap under all of the doors; that's actually part of what started this initial search. I was standing in front of my bedroom door and felt a ton of cold air rushing over my feet from under the closed door. I've read that even that gap, isn't good enough for a proper return when the door is closed?
The garage is not insulated, on any walls, but the kitchen doesn't seem to have problems getting too cold. The problem is really evident in the master bedroom and the other spare room that sits in the corner of the house.
If I do end up putting returns in each room, will they need to add up to a total area of the current return? It's fairly large, at least I think it is; the return grill is 14x25.5 inches.
The room seems to heat better with the door open, but it's still colder than any other room in the house. Definitely think that part of the problem is the old inefficient aluminum sliding door.
bobgodd 01-01-2013 02:04 PM
This is the current return:
http://i23.photobucket.com/albums/b3...101_105423.jpg
This is the crack in the bedroom slider:
http://i23.photobucket.com/albums/b3...101_105857.jpg
There was another crack on the outside that I sealed with caulk and I'm going to seal this one right now.
beenthere 01-01-2013 04:17 PM
[QUOTEAre you saying that I would use the existing location (after relocating the supply) as a transfer grill, or as a cold air return? My understanding of the differences between the two is a bit limited.][/QUOTE]
They can be used for either. Returns work better then transfer.
Your master bedroom needs an additional supply.
bobgodd 01-01-2013 05:21 PM
It's not an overly large bedroom. The whole house is only 1460 sq ft.
beenthere 01-01-2013 05:24 PM
Its not the size. That sliding door will have more heat loss then any of the other outside walls of the other bedrooms do.
bobgodd 01-01-2013 05:48 PM
Would that still be an issue if we're having the door replaced? The door will be replaced with a more efficient vinyl slider very soon.
beenthere 01-01-2013 05:51 PM
Yep, glass still transfers a lot of heat.
carmon 01-01-2013 06:03 PM
generally if you just push the air in with no return you wont be comfortable... the air needs to be pulled back as well....
Fix'n it 01-01-2013 07:36 PM
i would replace the doors first. that may be all/most of your problem. and your doing it anyway. after that, i would trim the bottom of the doors.
then go from there.
Focused2 01-01-2013 08:52 PM
Filter new?
You did not mention inspecting the condition of the air filter. Make sure that is fine, affects amount of air going through ductwork. You did not mention the location of the t-stat (thermostat). Normally near that return air grill in hallway. If you have ceiling fans see if they have a reverse, blows air into ceiling and brings down the hotter air near ceiling to the living area. Set it to low! Does not take much air to move warm air. Good luck with it, Joe
