Cold Air Returns - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 07:15 PM   #1
cold air returns
how many cold air eturns chould one furnace have? and how long should a cold air return be? and can a cold air return be in the same room as the furnace? i am really stuck i amremodeling my basement bathroom and the cold air return runs right thru the bathroom making the ceiling about 5' tall and would like to move but eed the questions first. if any one can i appreciate it. thank you
jlininger is offline   Reply With Quote
Old 01-12-2010, 07:37 PM   #2
An old Tradesmen
Rewards Points: 6,836
As many as need to return as much air as it needs to blow out.
As long as it needs to be. The longer it is. The bigger it must be.
Generally, you don't want a return in the same room as the furnace. As it can draw carbon monoxide fumes from the furnace.
Old 01-12-2010, 07:40 PM   #3
A return can not be within 10' (in the same room) of a gas furnace or water heater. If both are electric then it can be right on the return drop if you want.
How many returns depends on alot of factors like static pressure, size of system,size of duct, length of duct including equivalant length of all fittings and size and more.
Easiest way to find out where that duct in the bathroom can move is call a local HVAC contractor. They will provide you with a plan on how to do it right and a bid to do the job. Do it yourself with their plan if you choose to. Consulting fee is cheap.
Adding heat supplies and cold air returns to basement RAYCC3 HVAC 0 09-14-2009 01:57 AM
Cold Air Return(s) placement jbaker1516 HVAC 1 02-24-2009 01:16 PM
Re-routing cold air returns fjmb031507 HVAC 2 10-05-2007 10:07 PM
Cold air returns (or lack thereof...) Umby HVAC 7 07-06-2005 10:24 AM
