Cold Air Returns - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 08:04 PM   #1
Rewards Points: 192
Wink
Cold Air Returns
I am doing some renovations in my 1950 ranch style home and I have gutted the living room of all the drywall/plaster. I have two large 4"x10"air returns on the outside wall under a large 62"x68" window. In the basement they have used the joist bays as the return space. I would like to remove these from the wall and cut returns into the floor. My question is can I just use wood blocking to seal up the joist bay end as to cutoff air flow from the wall. I would then also seal up the sill with wood blocking as well so i can insulate this area. Does this sound okay to everyone? I know they have used sheet metal to seal the other side of the joist bay but my sheet metal working skills are not the best.
Thanks for you responses
bcgfdc3 is offline   Reply With Quote
Old 03-19-2012, 08:10 PM   #2
An old Tradesmen
Rewards Points: 7,802
Yes, you can use wood blocking.
Location of cold air returns Richo HVAC 9 10-13-2011 07:43 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
cold air returns zmkz HVAC 1 01-18-2010 05:52 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
Cold air returns (or lack thereof...) Umby HVAC 7 07-06-2005 10:24 AM
