Cold Air Return Question - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 09:47 AM   #1
My furnace and water heater will be enclosed by 3 walls: one to the living area, one to the hallway, and one to a bedroom. The rear of this utility room is partially open to the storage room, basically you can walk between this room and the storage room. The furnace is a 92% efficiency which pulls combustion air from inside. I will be installing a louvered door to this room as well. My question is can I place a cold air return in the wall which separates the living area and the furnace? This intake would be around the corner from the louvered door for the utility room. I've read about backdrafting and CO2 gasses but I'm not sure if that applies in this case. It will, however, be directly behind the furnace so it will be easy to tie into the cold air return.
NEW-B is offline   Reply With Quote
Vent Bath Exhaust to Cold Air Return? brandon272 HVAC 12 03-28-2011 05:11 AM
question about cold air return locations ponch37300 HVAC 4 01-11-2010 08:56 AM
Weak Cold Air Return sbhcom HVAC 1 12-11-2009 01:14 PM
Cold air return klein HVAC 1 01-07-2009 09:09 AM
Basement Cold air return Bcoleman6 HVAC 2 06-07-2008 08:42 AM
