Cold Air Return Idea??? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 05:29 PM   #1
Rewards Points: 280
Cold air return idea???
I've been busy with alarm system and not put much thought into AC. I am crawling around attic running alarm system wires and finding leaks in duct work!!
Anyway I had a thought while I was up there and did a quick sketch. Would it be possible to run cold air return out of plenum, so that duct layed in truss's. Or should I go back to plan A ????
JIm
jjrbus is offline   Reply With Quote
Old 08-06-2010, 07:54 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
Where in the world are you - Ghana, India or USA (Alaska or Florida)?
A plenum is usually a tern used for part of the air supply system and not the return system. Not a separate sytem, but it may makr your project of stringing wires easily, but not usually advisable.
Update your Profile to get better replies.
Dick
concretemasonry is offline   Reply With Quote
Old 08-06-2010, 10:17 PM   #3
An old Tradesmen
Rewards Points: 6,918
Hard to get the duct into the trusses after the gable ends are on.
Old 08-07-2010, 02:47 AM   #4
Rewards Points: 280
Thanks BeenThere!! I really missed the obvious on that one JIm
Cold Air return question Jay0018 HVAC 13 01-14-2010 04:35 AM
Cold air return, or not? toolman0114 HVAC 1 11-18-2009 05:55 AM
Cold air return klein HVAC 1 01-07-2009 09:09 AM
Looking for a better cold air return. Bcoleman6 HVAC 10 08-31-2008 02:42 PM
cold air return duffers HVAC 4 01-15-2008 07:37 AM
