Cold Air Return For A Garage Connected To A Home - HVAC - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 02:52 AM   #1
Unhappy
Cold air return for a garage connected to a home
I have two heat vents coming out from the walll connected to house basement seps go from this garage also. there is a front door and a back door only going out, turned into rec room and overhead garage door closed off. where should I install a cold air return it is always cold out here. should i put more heat vents out here also? about 300 sq. with also a back room added to this it was like a enclosed patio which is totally closed up no windows throughout either? any suggestions?
angielab is offline   Reply With Quote
Old 01-29-2012, 04:18 AM   #2
biggles's Avatar
just a raw garage turned into a rec room your trying to heat a brick..might consider a add on heating unit,and what insulation does the room have if any.the garage door is going to suck the heat might want to insulate the door with a wall of insualtion/plastic sheathing and sheet rock
The Following User Says Thank You to biggles For This Useful Post:
plummen (01-29-2012)
Old 01-29-2012, 07:26 AM   #3
An old Tradesmen
Rewards Points: 7,816
By closed off. Do you mean you have a wall framed up against the door.
Old 01-29-2012, 07:53 AM   #4
space heater.
hvac5646 is offline   Reply With Quote
Old 01-30-2012, 12:03 PM   #5
The garage door is framed off and insulated. The whole garage has insualtion and wood walls. We used a space heater last year and our electric bill went through the roof!!!
Old 01-30-2012, 03:41 PM   #6
An old Tradesmen
Run supplies to furtherest wall, and return at inside wall.
The Following User Says Thank You to beenthere For This Useful Post:
plummen (01-31-2012)
Cold air return bullmastiff135 HVAC 3 05-11-2011 04:37 PM
Adding on to cold air return agicr HVAC 13 03-27-2011 01:33 PM
Need advice on cold air return mrlouie HVAC 4 10-09-2010 04:33 AM
question about cold air return locations ponch37300 HVAC 4 01-11-2010 08:56 AM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
