Cold Air Return On Floor Q's - HVAC - DIY Chatroom Home Improvement Forum
Old 01-29-2014, 09:51 AM   #1
Rewards Points: 16
Cold air return on floor Q's
My house was built in the 50s and has central heating and a/c. All of the cold air returns are located on the floor under windows. So i assume the system was geared towards heating since the returns will collect the cold air off the floors from the windows.
We are looking to build an addition and i'm wondering if i should keep the same type of system (place the returns on the floor). All new builds i see have the returns high on the wall. Are there any rules that say you must have the returns on the wall? (i'm in Ontario). Thanks in advance.
cornation71 is offline   Reply With Quote
Old 01-29-2014, 03:54 PM   #2
MarginallyQualified
Rewards Points: 2,464
That is backwards.
Supply to the exterior; return on the interior.
Nope; but it does make sense to *also* have high returns.
The Following User Says Thank You to TarheelTerp For This Useful Post:
COLDIRON (02-05-2014)
Old 01-29-2014, 05:59 PM   #3
An old Tradesmen
Rewards Points: 7,332
Originally Posted by TarheelTerp View Post
That is backwards.
That was done for a while in the 50s. The thinking was to keep the cold air from entering further into teh room. They found out it didn't work well.
High or low won't make much difference as long as the correct supply registers are used.
The Following User Says Thank You to beenthere For This Useful Post:
plummen (02-04-2014)
Old 01-30-2014, 08:35 AM   #4
Rewards Points: 16
The main floor addition will be an open concept 16x24 room. Would one return be enough? I was toying with the idea of having a high and low return in that room where i could shut the upper return in the winter and vice versa in the summer.
Old 01-30-2014, 03:39 PM   #5
An old Tradesmen
1 wall cavity won't be enough return. Will need to use 2 wall cavities.
Old 01-31-2014, 12:59 PM   #6
Rewards Points: 808
I've never seen return registers on the floor or under windows.
IslandGuy is offline   Reply With Quote
Old 02-04-2014, 02:41 PM   #7
Rewards Points: 16
They're in almost every house in my area. Houses built around the 1950s.
Old 02-04-2014, 07:08 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
That is backwards.
Thats the way things were done back in the day.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Cold Air Return Duct in Garage Ceiling (for bedroom above) jbrocious HVAC 8 10-15-2012 04:52 PM
Adding on to cold air return agicr HVAC 13 03-27-2011 01:33 PM
moving my cold air return Bill Smith Building & Construction 2 11-27-2010 10:35 PM
Need advice on cold air return mrlouie HVAC 4 10-09-2010 04:33 AM
Cold air return, or not? toolman0114 HVAC 1 11-18-2009 05:55 AM
