Old 10-28-2012, 11:41 AM   #1
Cold Air Return Filter
during the warmer months, i get spiders coming up through my cold air return vents. is it ok to put a filter inside the cold air return vents? will that choke off the furnace?
Uploaded with ImageShack.us
Scully is offline   Reply With Quote
Old 10-28-2012, 11:44 AM   #2
bbo
normally if you have spiders, thats a sign of bugs as well.
I'm thinking during the warmer months, get a dehumidifier running to remove moisture from the air, this will lessen the bugs and spiders that eat them.
Adding a filter on those vents will lessen the effectiveness of your cooling/heating system. you would have to increase the area of the vent to keep the same flow rate.
bbo is offline   Reply With Quote
Old 10-29-2012, 12:44 AM   #3
Fraid of spideys?
bobelectric is offline   Reply With Quote
Old 10-29-2012, 11:33 AM   #4
JJboy's Avatar
you need mastic all open space inside of the return box
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-29-2012, 12:10 PM   #5
how
A temp rise test across the furnace will tell you if / or how restrictive a filter you can put on your return air.
The mastic on the duct joints helps unless you have a fresh air vent attached to your return air duct.
I think realizing that spiders only consume other home bugs makes many folks more tolerant of them.
how is offline   Reply With Quote
Cold Air Return issue ra1185DIY HVAC 1 12-05-2010 04:21 PM
Cold Air Return Question avtck HVAC 3 01-08-2010 08:47 PM
Cold air return, or not? toolman0114 HVAC 1 11-18-2009 06:55 AM
Basement Cold air return Bcoleman6 HVAC 2 06-07-2008 09:42 AM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 11:54 PM
