Cold Air Return In The Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 12:33 AM   #1
dvj
Cold air return in the basement
Hello, I need to take a cold air return in the basement to the floor level. One of the options I was considering is to cut the top plate as shown on the image (stud on the left is missing) and cover the space between the joists with sheet metal for the upper part. For the vertical part of the duct, I was going to use the space between the studs and the wallboard. Another option, less preferable, is to connect a flange with an elbow pipe at the top without cutting the stud. Would it be acceptable to use the first option or I have to do it with a flange and an elbow?
dvj is offline   Reply With Quote
Old 01-26-2011, 12:29 PM   #2
Your first option is the way its done. Before you cut out the plate, make sure it's secured in a few spots to the joists to give the wall a bit more strength (it looks like it already is from your picture). I'd also put pieces of drive cleat across the cut out section on both sides of the wall.
hvac benny is offline   Reply With Quote
Old 01-26-2011, 12:34 PM   #3
dvj
Thanks a lot for the suggestion to put drive cleats!
Tags
air , basement , cold , return
Thinking of relocating Basement return, good idea? Windwalker HVAC 0 12-19-2010 12:49 PM
Cold Air Return issue ra1185DIY HVAC 1 12-05-2010 04:21 PM
HEating vents and cold air return in basement hazey313 Building & Construction 3 09-30-2010 09:55 PM
Installing Cold Air Return (Basement) kwtsat HVAC 3 07-22-2008 07:58 PM
Running network wiring in a cold air return vent? mcvane Electrical 26 04-19-2007 08:52 AM
