-   -   cold air return (http://www.diychatroom.com/f17/cold-air-return-38336/)
ponch37300 02-14-2009 04:56 PM
cold air return
I knocked out a wall that had 2 cold air returns in it, one on each side. I framed up a knee wall and need to replace the cold air returns. Don't have much experience doing heating. Can I put both returns in the same stud cavity? Also for the return I just cut the floor out and the drywall and put a peice of sheet metal to block off the top? Thanks for any help with this.
yuri 02-14-2009 05:31 PM
That works just fine.
beenthere 02-14-2009 05:39 PM
Using the same cavity for both returns, limits the amount of return you can draw from the rooms.
A single wall cavity, is seldom big enough for one room, let alone 2 rooms.
ponch37300 02-14-2009 05:53 PM
Is this just because the 3 1/2" x 14 1/2" whole going threw the floor doesn't let enough air flow threw it? Thanks for your help
beenthere 02-14-2009 07:11 PM
Yes.
It can only handle x amount of air.
ponch37300 02-15-2009 06:49 PM
Alright, I am putting the returns in 2 different stud bays. This is in a knee wall that is 2x6 framing. I couldn't find any metal plates made for "caping" off the stud bays above the returns. So can I just use a piece of 2x6 for the top? Also when I cut the bottom plate out do I just cut the whole thing from stud to stud out? Thanks for your help
beenthere 02-15-2009 07:08 PM
A 2x6 plate is fine.
Make sure you caulk around it, to make sure its air tight.
NO. DO NOT cut the whole 2 x 6.
But, if you do, by accident. Use a framing plate to rebrace it.
ponch37300 02-15-2009 07:42 PM
Beenthere, Thanks for the help. What is the best way to cut the bottom plate and how much should I cut out? Most of the returns I've seen in 2x4 walls have had the whole bottem plate cut out in between the studs. Thanks
beenthere 02-15-2009 09:49 PM
I sawzall them.
In the old days, we cut them out completely.
Not really allowed by code anymore.
Some places make us use a braze plate, no matter what when we cut a return through the cavity.
I try to leave a " on the 2 x 6, and an inch at the ends.
ponch37300 02-15-2009 09:55 PM
Thanks for all the help Beenthere.
