Cold Air Return - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 08:10 AM   #1
Cold air return
I have at least a one inch gap under my bedroom door. I was planning on cutting in a cold air return in the wall but was wondering if the gap is letting enough air back through already. The furnace has a central cold air return in the basement hallway and the plan was to put in a "pass through" vent in the bedroom wall. It's been functioning alright w/o it so far but I don't know if I should still cut a hole in my wall if I've got this huge gap under the door.
klein is offline   Reply With Quote
Old 01-07-2009, 10:09 AM   #2
The gap under the door will serve you fine. In fact that's one of the reasons it's like that.
The problem with a passthru vent is that it will allow sound to pass right thru too, which is usually not a good thing.
I would be inclined to suggest, if it ain't broke, don't fix it.
PS Oh yeah, the whole reason I clicked on your thread, was to point out that "Cold Air Return" is a bit of a misnomer and a personal pet peeve of mine. It's much more accurate to leave off the "cold air" bit and just call it return.
Garasaki is offline   Reply With Quote
Running wire through a cold air return? beezlebub03 Electrical 37 02-28-2010 11:57 AM
Basement Cold air return Bcoleman6 HVAC 2 06-07-2008 09:42 AM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 01:43 AM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 11:54 PM
