Cold Air Return - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 11:41 AM   #1
Cold Air return
I have a question.
A central A/C and heat pump has been put in my home, there are 2 bedrooms, 1 bath, and an open floor plan that joins the livingroom and kitchen.
There is 2x12 supply vents in the house- 1 in each bedroom, and 2 in the living room... will be adding more eventually. These are all 6 inch flex ducting
The cold air return is wide open to the basement and currently is drawing air through the basement door- I need to add a cold air return vent-- do I add 1 in the central part of the house in the floor near the thermostat- or would it work to us 6 inch flex ducting and a 2x12 in each room as a return? It has to be in the floor because the walls are plaster and are too skinny to accommodate ducting.
faith_factor is offline   Reply With Quote
Old 11-07-2013, 02:22 PM   #2
FClef's Avatar
Rewards Points: 160
Open air returns in a basement, finished or not, are a bad idea overall. While a central, ducted return from a side wall or a ceiling would be better, it still isn't ideal.
What is best is to have individual returns in each room if that is possible. It will insure that, even with the door closed to the room, you will get the right amount of air flow to properly heat/cool the room. Central returns need to be able to pull the air back to the air handler from each room. If it cannot, it can cause uneven heating/cooling in rooms.
Your overall duct sizing for returns is another matter entirely. If the duct isn't sized properly you may not be bringing enough air back through the unit and that can cause coil freezups, poor heating and premature failure of components because of the added work the unit must do to compensate. This is one of those times where you may want to think about getting a professional to look at the system. If that is not an option for you then we may be able to help you but it is going to require more information overall.
"Human beings can always be relied upon to assert, with vigor, their God-given right to be stupid"
Dean Koontz - Seize The Night
FClef is offline   Reply With Quote
The Following User Says Thank You to FClef For This Useful Post:
faith_factor (11-07-2013)
Old 11-07-2013, 05:37 PM   #3
An old Tradesmen
Rewards Points: 6,112
Put a large return near the thermostat, and 1 in each bedroom(7" flex to a 4x10 in bedrooms).
The Following User Says Thank You to beenthere For This Useful Post:
Old 11-07-2013, 07:03 PM   #4
Thank you for the responses- this helps
Cold Air Return Duct in Garage Ceiling (for bedroom above) jbrocious HVAC 8 10-15-2012 05:52 PM
Adding on to cold air return agicr HVAC 13 03-27-2011 02:33 PM
moving my cold air return Bill Smith Building & Construction 2 11-27-2010 11:35 PM
Need advice on cold air return mrlouie HVAC 4 10-09-2010 05:33 AM
Cold air return, or not? toolman0114 HVAC 1 11-18-2009 06:55 AM
