Cold Air Return - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 04:36 PM   #1
cold air return
on my cold air return duct, just before it heads thru the filter and into the furnace are two grilles. When the HVAC technicians installed the new ac, they said i should keep the grills open. Why? Is that only during the summer and not during the winter? The air is blowing out of the grills. is that normal?
duffers is offline   Reply With Quote
Old 01-14-2008, 04:40 PM   #2
Union HVAC Tech.
The a/c needs more return air than you have ducted so they added the grilles in an effort to get more air back to the drive for cooling season, the last thing you want in heating mode is to pull air from around the furnace, that could cause combustion problems. The real solution is to add more returns to the system.
bigMikeB is offline   Reply With Quote
Old 01-14-2008, 04:48 PM   #3
no the air is blowing out those grills not in.
Old 01-14-2008, 04:51 PM   #4
Union HVAC Tech.
Then it can't be on the return. You may feel air movement, try and cover them with a piece of paper and see if they blow or pull.
Old 01-15-2008, 08:37 AM   #5
u are correct.. it was pulling the air in. So i should keep those vents open in the summer and closed in the winter?
Running network wiring in a cold air return vent? mcvane Electrical 26 04-19-2007 08:52 AM
What size should cold air return grille be? AllGoNoShow HVAC 1 02-27-2007 04:48 PM
Repositioning cold air return bgefire HVAC 1 11-19-2006 02:01 PM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 11:54 PM
