Cold Air Return? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-27-2012, 06:47 PM   #1
Cold Air Return?
My wife and I are purchasing a home that we would like to take a wall down between the dining room and kitchen. Already know it is not a load bearing wall. It has two cold air return vents on it. The one in the dining room is 14 inches wide and at the top of the wall and the one in the kitchen is three feet wide and near the floor. We would like to shorten the three foot one to make it 14 inches (or completely remove it?) to allow more space for the wall to come down. Is that advisable to shorten a cold air return vent or get rid of it?
Thanks, NJHummel
njhummel is offline   Reply With Quote
Old 03-27-2012, 07:13 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
you should not have a return in the kitchen!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-27-2012, 07:35 PM   #3
why not?
Old 03-27-2012, 07:43 PM   #4
MarginallyQualified
Rewards Points: 2,464
No.
In almost every instance houses have inadequate return air volume...
so if you're to make changes you'll want to INCREASE the cubic feet of air.
Mostly what you need is a qualified HVAC person to evaluate your air volume needs and the best location to draw the return air from.
You want to avoid return air registers in kitchens (and baths) because spreading the odor and grease laden air from these areas doesn't help anyone.
Old 03-27-2012, 08:00 PM   #5
how easy is it to relocate an air return vent?
Old 03-27-2012, 08:22 PM   #6
AKA HVACTECHFW
Every home is constructed differently so it would depend on how the current setup is.
IT IS WHAT IT IS
Adding on to cold air return agicr HVAC 13 03-27-2011 01:33 PM
moving my cold air return Bill Smith Building & Construction 2 11-27-2010 10:35 PM
Need advice on cold air return mrlouie HVAC 4 10-09-2010 04:33 AM
Cold air return, or not? toolman0114 HVAC 1 11-18-2009 05:55 AM
Looking for a better cold air return. Bcoleman6 HVAC 10 08-31-2008 02:42 PM
