Cold Air During Defrost. What Is Wrong? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 05:22 PM   #1
Cold air during defrost. What is wrong?
http://www.docs.hvacpartners.com/idc...blic/documents
/techlit/ag-faeh-06.pdf
Hello,
So I recently had IAQ stat(9421) + EIM installed. I have an all electric heat pump + air handler (1 cool 2 heat):
Air handler:
Product # FC4BNF036000AEAA
Model # FC4BNF036
HEAT PACKAGE (10KW):
KFAEH2201H10
Heat pump:
Product # 697CNX030000ABAA
Model # 697CN030-B
Heating and the stat work ok, but I have noticed that, during defrost, cool air is blown from the registers.
Both "emergency heat" and "aux." heat work ok.
Manually setting stat to "em heat", in which case outdoor unit is off or raising stat's setpoint a few degrees, in which case both het pump and heat strips are on.
Could someone help figure out what could be wrong (may be 1 wire was missed to be wired)?
Manual for my air handler:
http://www.docs.hvacpartners.com/idc...lit/sm03-5.pdf
Description of my the air handler's "smart heat" low voltage terminal board starts on page 46
The schematic for the board is in Fig. 39—Smart Heat Printed-Circuit Board (PCB).
Diagram on page 51.
Manual for my heater package:
http://xpedio.carrier.com/idc/groups...ag-faeh-06.pdf
Description of my heater package and its functions starts on page 4
Diagram on page 12.
My condensing unit is not equipped with outdoor thermostat.
What I don't understand is this:
How does the air handler board "know" to activate backup heat during defrost?
On the air handler board, there is W2D terminal (defrost input from outdoor unit).
There is also w2T terminal on the control board - it's used to activate emergency heat or auxiliary heat.
What I don't understand is how does the signal for defrost is processed by the air handler's control board and how should the wiring be set up for it to activate emergency heat during defrost.
From outdoor unit, W1 wire goes up to W2D terminal on the board.
From the EIM, Aux wire goes to w2T on the board.
Should there be another wire from EIM "Aux" terminal to the board w2D?
Thank you!
stant98 is offline   Reply With Quote
Old 01-12-2011, 05:58 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
hook w1 from outdoor to w2t with eim wire. also you can check for 24v on w1 during defrost. this is the signal that should be going to ah
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 12:21 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
All the best equipment... Done Wrong?!?! ludehawk HVAC 8 12-31-2008 03:22 PM
posted in wrong spot- cold air wood grates??? 4just1don HVAC 1 12-16-2008 12:50 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 12:43 AM
