Cold Air Coming Out From Vent Once Furnace Stops - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2011, 03:02 PM   #1
Cold air coming out from vent once furnace stops
I really need your help to figure out what's going wrong.
Bought a house (built in 2006) with furnace located on attic. At night, when it's getting cold, the furnace starts to work, and it's fine. But when it stops, I can feel some cold air coming out from vents.
Even worse, the downstairs has no such problem. it only happens in two upstairs bed rooms!
My wife did a quick search and suggested it's back draft damper problem. But why other rooms are OK if it's damper problem.
I check the duct tape and it seems OK.
Thanks for your any advice.
Best
Neil
neilkent is offline   Reply With Quote
Old 10-07-2011, 05:37 PM   #2
Rewards Points: 6,652
The main question is, are the ducts insulated. If you are getting cold air after the unit stops running, there is air leaking into the duct work some way, which needs to be checked out.
Old 10-07-2011, 06:25 PM   #3
I'd like to know a real temperature of the air please. Also measure the temp at the other vents upstairs so we have something for a comparison.
Old 10-07-2011, 08:02 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
So the heat cycle satisfies and the heat stops but in two rooms only you can continually feel air as if the blower is still spinning? Is that right? That strong?
For how long? And as Marty has already asked, we'd need some air temperatures, please.
Doc Holliday is offline   Reply With Quote
Old 10-07-2011, 09:18 PM   #5
biggles's Avatar
was it always like this upstairs?is the return ducted to the back of the attic unit?is the attic cold when the unit is running?also a biggie here check 360 degrees around the 2 conections of the furnace make sure the bottom is sealed tight on that return and supply.is the furnace induced draft or static vented?......just asking
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
