A Coils - HVAC - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 01:33 PM   #1
Unhappy
A coils
I have a trane unit 2years old the a coil is at room temp at the top and cold in the middle and bottom tech told me it was a bad a coil or expansion valve have you hers of this problem.
Im4ou2 is offline   Reply With Quote
Old 07-11-2011, 03:24 PM   #2
Does it cool your house to the temp you want ? What problem makes you check your coil temp ?
clocert is offline   Reply With Quote
Old 07-11-2011, 06:12 PM   #3
An old Tradesmen
Rewards Points: 6,462
Could also just be low on charge. can't tell without the numbers from the gauges and temp probes.
Heat coils on same time w/ AC reevtd HVAC 9 03-09-2011 05:58 PM
Dehumidifier - Compressor Running, Coils Warm BennyB HVAC 1 02-18-2011 05:29 PM
Seer 10 evap coils bad, Go to Seer 13??? pcumming HVAC 5 09-01-2010 06:21 PM
Coleman Leaky Coils rdwacw HVAC 1 07-15-2010 11:30 PM
Accessing Coils on inside Goodman A/C jmblair HVAC 1 05-20-2009 01:41 PM
