Coil Resistance Of Compressor Relay - HVAC - DIY Chatroom Home Improvement Forum
Old 06-12-2009, 11:22 AM   #1
Coil resistance of compressor relay
Ten ohms sound about right?
With coil impedance at 60 Hz, it pulls ~1A from the 24vac 'former?
Thanks in advance.
Old 06-12-2009, 06:37 PM   #2
An old Tradesmen
Rewards Points: 6,068
Too low.
Old 06-12-2009, 06:49 PM   #3
Originally Posted by beenthere View Post
Too low.
That's what I thought, but now the whole thing is working.
Had 24vac into the sending end of the control wires to the outside compressor,
20vac out when the receiving end was open-circuited
but zero when connected,
and zero current flow when connected. . .?
It was a bad wire nut connection outside that my HVAC guy made years ago. It came apart in my hand.
For these symptoms the connection must have been acting like a very high resistance.
I should measure the coil AC current while everything is still ticking. Getting contactor coil specs off the Internet seems pretty difficult.
Old 06-12-2009, 06:55 PM   #4
An old Tradesmen
Thet're not generally published.
Evap coil question merlinfolks HVAC 15 07-27-2009 08:20 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 01:43 PM
Replacing a 2 ton A coil with a N coil with TX valve englewood1 HVAC 7 09-11-2008 01:09 PM
help, Poor performing AC, coolant leak? damaged coil? images maverick06 HVAC 5 07-31-2007 06:30 PM
