A-coil Plugged - HVAC - DIY Chatroom Home Improvement Forum
Old 06-10-2015, 06:38 PM   #1
Rewards Points: 12
a-coil plugged
I run my air conditioner and water from the a-coil backs up and run all on the inside of the furnace. The plastic tube for the runoff has no water in it at all. What tool do I need to suck the blockage out? Thanks in advance.
JMATT01 is offline   Reply With Quote
Old 06-10-2015, 07:42 PM   #2
user_12345a's Avatar
Rewards Points: 1,084
a-coil plugged
wet/dry shop vac
user_12345a is offline   Reply With Quote
Old 06-10-2015, 09:19 PM   #3
Retired from the grind
gregzoll's Avatar
Rewards Points: 4,266
a-coil plugged
A Air compressor also works to blow down into the line. It should have a T at the top of the line, to allow Hot water to flush it out, along with blowing it out.
If you are getting a gunked line. Your unit is most likely not running long enough after the outside unit shuts down. The one place you see this happening as a common occurrence, is in units placed in attics.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 06-12-2015, 10:55 AM   #4
Rewards Points: 1,149
a-coil plugged
In the old days when R22 was cheap , I saw service techs blow out the drain lines with R22 .
God bless
Wyr
WyrTwister is offline   Reply With Quote
First time Coil clean but on Gas Furnaces kilosos2 HVAC 19 04-26-2014 09:46 AM
Mother in law coil cleaning digitalplumber HVAC 8 08-13-2012 06:31 PM
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 03:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
