Coil Not Cooling - HVAC - DIY Chatroom Home Improvement Forum
Old 07-20-2012, 12:18 PM   #1
Coil not cooling
I am working on a Carrier A/C Model 50hs 060 301ab...I have replaced the compressor and the check-in valves and the coil will not cool, the lines freeze up before they get to the coil.
saul714garcia is offline   Reply With Quote
Old 07-20-2012, 07:40 PM   #2
An old Tradesmen
Rewards Points: 7,332
Did you replace the liquid line filter drier.
Old 07-21-2012, 12:56 AM   #3
I did not...that is my next step thank you. i will let you know my result.
AC - Coil leaking fcabanski HVAC 7 07-04-2012 09:50 PM
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 03:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
cooling coil formulas? Tinman_iii HVAC 8 06-05-2009 08:33 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
