A-Coil Mortex-Mobile-Home - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 09:39 PM   #16
Thank You Doc, I'm GENTLE
gracie777 is offline   Reply With Quote
Old 04-17-2012, 09:40 PM   #17
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by gracie777 View Post
I am also going to re insulate the low suction line as well as the one that installed the unit used the old insulated foam and water is appearing on the black tape on that suction line. LoL the drain line he put in was a plastic flexi tube and wasn't even hooked up to the drain line coming up from the floor, I had to get a plumber to come correct that issue
The instructions that come with those evaporators for downflow modular home electric air handlers say to extend that plastic flex drain line and make a P trap out of it, holding it in that shape with a special band that comes with the evaporator. That flex line extends to something like 5 or 6 feet long. Then connect to pvc which should run to outside the perimeter of the home.
Yeah, good idea to change that insulation to 1" thick. You seem to have a lot of moisture being pulled from the air.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-17-2012, 09:43 PM   #18
<hiding behind hands in front of face, peeping through fingers like when watching a scary movie> I believe you.
Thanks.
Old 04-17-2012, 09:47 PM   #19
I re-posted a pic showing the drain line
Old 04-17-2012, 09:48 PM   #20
I just don't want you to mess those lines up and them come back and say I told you to do it. I know I could re-arrange them without batting an eyelid as I've had plenty of practice doing so, I do this for a living. Yourself on the other hand need be extremely careful.
Okay, that's all I'll say about it. Let us know how you fair.
Thanks.
Old 04-17-2012, 09:51 PM   #21
LoL Doc, at least I got a laugh, have been upset as I've called the HVAC Company 5 times and before I called a plumber and all I got was I'll call you back and come fix it, nope didn't happen, and the Company hasn't even sent me the bill, maybe they won't charge me. LoL
Old 04-17-2012, 09:52 PM   #22
I see it, pretty dumb.
I'd pull that black line down and out to under the home, cut the hole a bit bigger in the floor to accomodate the flex tube to go through and connect the lines under the home but that's just me. A properly sized and tightened down hose clamp will connect the two which again, I'd have the connection under the home, just in case of any leaks. It's one solid line to under the home the way I'm talking about and how I do it on all the modular homes I work on.
Thanks.
Old 04-17-2012, 10:00 PM   #23
I would not say you told me to do it, I looked at your profile and I saw you did this for a living, I think it might be best to have another HVAC Company come to my home and do it.
Old 04-17-2012, 10:04 PM   #24
I really appreciate your advise, your kind to help, Thanks a BUNCH
Old 04-17-2012, 10:08 PM   #25
You're more than welcome and again, let us know how it turns out. Plus now you know where to come for all your household repair needs so come back anytime, even just to BS in the off topic section.
Thanks.
venting from mobile home through new metal roof jeanmoon Roofing/Siding 8 05-01-2015 08:53 AM
running electric under mobile home brianbrianj Electrical 8 10-26-2014 02:16 PM
Coleman DGAA mobile home furnace issue baluna HVAC 9 04-07-2012 08:55 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
