A-Coil Mortex-Mobile-Home - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 09:02 PM   #1
I just had a HVAC Company install this A-Coil unit and the right side, copper lines over laps the drain pan, condensation drips off the copper coil lines on the floor. How can I fix this issue?
A-Coil Mortex-Mobile-Home-my-unit-oh-my.jpg   A-Coil Mortex-Mobile-Home-new.jpg   A-Coil Mortex-Mobile-Home-just-.jpg
gracie777 is offline   Reply With Quote
Old 04-17-2012, 09:12 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-17-2012, 09:13 PM   #3
Have it insulated up and into the coil cavity as far as it can be.
Thanks.
Old 04-17-2012, 09:15 PM   #4
Modular home, 101.
Thanks.
Old 04-17-2012, 09:58 PM   #5
ok Thank You
Old 04-17-2012, 09:59 PM   #6
Could I wrap the copper lines with cork tape
Old 04-17-2012, 10:11 PM   #7
Rewards Points: 614
cork tape would work..messy to remove though
carmon is offline   Reply With Quote
Old 04-17-2012, 10:16 PM   #8
yes, as it is a tacky rubbery substance.
Old 04-17-2012, 10:19 PM   #9
Rewards Points: 614
foam tape would work as well...
Old 04-17-2012, 10:21 PM   #10
The sad thing is under those lapping copper lines is only black tape
Old 04-17-2012, 10:24 PM   #11
I just now noticed the circled bit. Sorry, I was talking about the low suction line, the biggest copper line coming down the left side which is supposed to be insulated. You can easily (but carefully) push those little circuit lines up and over to where they are over the drain pan. No insulation on those little circuit lines needed ever.
You don't want to damage as in bend them as in kink them and you want to be careful to not break them from their seals where they enter the evaporator. You can actully move that entire piston orifice around with those little lines.
No biggy, just be careful.
Thanks.
Old 04-17-2012, 10:24 PM   #12
Thank You Carmon, foam tape would stop the condensation?
Old 04-17-2012, 10:26 PM   #13
Ok Thank you Doc
Old 04-17-2012, 10:27 PM   #14
The bolt in the middle, grab it and gently push it in. Those little lines will follow. You can also push the little lines themselves but again, don't damage them.
BE GENTLE.
Thanks.
Old 04-17-2012, 10:34 PM   #15
I am also going to re insulate the low suction line as well as the one that installed the unit used the old insulated foam and water is appearing on the black tape on that suction line. LoL the drain line he put in was a plastic flexi tube and wasn't even hooked up to the drain line coming up from the floor, I had to get a plumber to come correct that issue
venting from mobile home through new metal roof jeanmoon Roofing/Siding 8 05-01-2015 09:53 AM
running electric under mobile home brianbrianj Electrical 8 10-26-2014 03:16 PM
Coleman DGAA mobile home furnace issue baluna HVAC 9 04-07-2012 09:55 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 06:27 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
