A Coil Installation - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-23-2008, 06:33 AM   #16
An old Tradesmen
Rewards Points: 6,560
Doesn't matter if its 2 days, 2 hours, or 2 months.
If the blower can't move enough air, it will freeze the coil, and most likely harm the compressor.
They probably make an upgraded blower for A/C.
What brand is the furnace.
Old 12-23-2008, 02:29 PM   #17
The furnace is made by intertherm. I'm not sure if the blower is original but it is very strong, loued and moves a lot of air around the house.
I'm actually entertaining another idea. I've found a complete used unit on craigslist that was removed from a remodeled home. The system is much newer and the price is reasonable. Will it make it sense to pursue this avenue? what type of questions and information should I ask and gather? Thanks.
Here is some background info
mobile home is single wide 14x6x (~1060 sqft)
bekind42 is offline   Reply With Quote
Old 12-23-2008, 03:41 PM   #18
Mobile homes are design certified for a specific brand and model furnace. For a newer mobile home choosing a replacement furnace is not a problem as many diff brands now use standardize units. Not so with mobile homes of thirty years.
You would be better off buying a heat and cool pkg unit instead.
hvaclover is offline   Reply With Quote
Old 12-23-2008, 05:25 PM   #19
An old Tradesmen
You would need to know the size of your unit, and teh one you looked at.
And also need to know if it has an A/C blower or not.
A package unit, may be a much better way to go.
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Replacing a 2 ton A coil with a N coil with TX valve englewood1 HVAC 7 09-11-2008 01:09 PM
Central Air Installation Question ??? WorkOnIt HVAC 3 03-07-2008 05:04 PM
help, Poor performing AC, coolant leak? damaged coil? images maverick06 HVAC 5 07-31-2007 06:30 PM
