Coil Clean - HVAC - DIY Chatroom Home Improvement Forum
Old 09-01-2014, 05:27 PM   #1
Rewards Points: 528
coil clean
On basic heat pump systems when you have a service call for regular maintinence should the unit coils be cleaned before or after the testing of the unit?
hidden1 is offline   Reply With Quote
Old 09-01-2014, 05:53 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 386
I inspect the indoor one if it is accessible. If the outdoor one is very dirty I wash it and then check the unit. If not so dirty I start it and do a basic check. Then I wash it and recheck. If it is cold outside/ below 70F you have to be careful as a wet coil will give false discharge pressures etc. Takes forever to dry properly. That is why getting some basic readings first helps.
First time Coil clean but on Gas Furnaces kilosos2 HVAC 19 04-26-2014 09:46 AM
New furnace this winter, now freezing ac coil. robsmale HVAC 12 07-17-2012 01:37 AM
AC - Coil leaking fcabanski HVAC 7 07-04-2012 09:50 PM
Should I clean my A coil? viper HVAC 8 06-20-2012 08:17 AM
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
