Codes For Covering Up Furnaces... - HVAC - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 12:35 PM   #1
Rewards Points: 14
Codes for covering up furnaces...
Hello,
I am a firefighter and I asked my fire Marshall's that I work with and they weren't sure. I recently got an old house in which they started a remodel. They tore off the drywall to remodel and left it uncovered. I want to replace the insulation and cover up the wall with hardibacker or some type of cement board I just wanted to make sure that it was ok to cover up the wall with this. Is there a certain minimum clearance there must be? Also is it ok to have the insulation so close to the heater vent? I have attached an image of the current wall/insulation.
Thanks,
Ian
socrates is offline   Reply With Quote
Old 09-02-2012, 01:19 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by socrates View Post
Hello,
Thanks,
Ian
The appliance will have the designated clearance requirements on the unit...
Old 09-02-2012, 01:41 PM   #3
HOTDAWG
Without the manual or specs on the unit, we can only suggest clearances, most of the older furnaces want 1-2 inches off the back and sides. I would definitely use an approved insulation around the vent. If your able to post the make and model of the unit we can try and pull up the specs and have a look.
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
Old 09-03-2012, 09:50 AM   #4
Is this furnace an electric furnace or a gas furnace. If it gas, then the IFGC has a minimum clearance requirements for all gas appliances. Hope that helps. You can purchase the International Fuel Gas Code Book from the International Code Council website. I think the paperback book is about $80.00. Good literature to have on hand if you are doing ANY projects around the house. This will keep you safe, plus, if you are a DIY, you can perform these projects and when you sell your house in the future, you won't have a bunch of gas code violations that need correcting for the new owner.
robwilliams is offline   Reply With Quote
Help me identify these things on two furnaces, pics included amodoko HVAC 4 08-09-2012 04:24 PM
What brand of furnaces do you work on? R u brand specific? Liberator HVAC 7 01-25-2012 08:17 PM
I have a Coleman Furnaces DGAA077DTB and I want to install a A/C unit to it. yoshua HVAC 1 06-14-2011 11:19 PM
Twinned Furnaces Questions MrControls HVAC 12 12-13-2008 10:09 AM
2 furnaces 1 thermostat clarnp49 HVAC 3 12-05-2007 08:12 PM
