Code For Insulation - HVAC - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 01:09 AM   #1
Code for insulation
I've got a copy of the book "Code Check" indicates R-6 insulation in floor trusses, R-8 elsewhere with EXC, and lists that the code is 1103.3 of 09 IRC and 605.0 of 09 UMC. But I can't find copies of the 09 codes to get details (only 06 at bulk resource).
Can someone fill me in on the details.
HooKooDooKu is offline   Reply With Quote
Old 05-18-2010, 02:50 AM   #2
Good question. At times a code requirement will be written and included in the latest code book but a city might not get around to adopting the new code book for several years.
The codes you mentioned are in print but not too many are around because none are going to be adopted for a couple years.
My own city is working from a code adopted in 2006
hvaclover is offline   Reply With Quote
Old 05-18-2010, 08:30 AM   #3
Our city adopted 2009 requirements in January... if I would have submitted my building permit just a little earlier, I'd be under the 2006 rules. But because I couldn't get my plans together before February, I'm under the 2009 rules.
Old 05-18-2010, 08:51 AM   #4
Here we have to have an energy audit before we can even apply for a permit
I generally pass by 25% (or more) what is required for insulation
I'd rather pay more for insulation then pay more long term in heating costs
R13 walls - I use R19 or may possibly use R22
I think R30 is min for roof, I use R38 or better
Floor over the garage I will be using R30 or R38
I'm even insulating the unheated garage walls w/R19
Old 05-18-2010, 11:12 AM   #5
Sorry for not being specific enough...
I'm looking for what the code says (specifically the exceptions) regarding insulation for HVAC ducts. The 2009 codes increased the required R Value. I have "Code Check", but it only gives the highlights, not the details.
Electrical re-wire to code diy-safely Electrical 8 01-04-2010 03:19 PM
frigidaire oven/range trouble code F1 Pete Sloniker Appliances 0 12-12-2009 07:28 PM
code details for boxes kama Electrical 6 01-30-2009 10:25 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
