Code 31 With Carrier Weathermaker 9200 58mxa - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 12:09 AM   #16
How to tell when it was put in
I can't remember, will the serial number get its age do you think
jbander is offline   Reply With Quote
Old 01-25-2012, 12:12 AM   #17
[quote=jbander;834065]
Originally Posted by harleyrider View Post
i have made claims on that suit as close as 9 months ago, so i am assuming they extended it? I know for a fact that carrier is (was) still paying labor to replace them (have to jump through several hoops) as late as this past October. so i guess the moral of this story is.......DO GIVE UP![/quote
Why should I give up? or did you mean don't give up
dont give up
harleyrider is offline   Reply With Quote
Old 01-25-2012, 01:16 AM   #18
you CAN NOT see this area with out useing a high resolution in-fared HVAC camara......it is above or below (depending on your furnace oreintation) the blower.
So I can pull the blower and see this.
Old 01-25-2012, 07:27 AM   #19
HVAC Tech/Owner
Rewards Points: 604
Many times it doesn't take pulling anything....there is water where it shouldn't be. The lawsuit prompted carrier to extend the warranty's on the secondary hx, but there is an extensive checklist to go thru because the failures were attributed to improper installs. Primarily, the HX's had to be sloped correctly to drain the acidic condensate water that would sit in the secondary and eat thru the walls.
I recommend to all my customers to take the credit carrier will give to get a new furnace. The key to most hvac problems is having a competent company install the furnace in the first place.
Technow is offline   Reply With Quote
Old 01-25-2012, 07:42 PM   #20
There is not a drop of anything or rust spot under the fan, it's set up as a updraft .
I had a furnace man out, I assume he was licensed had a big yellow page ad he said to get a new pressure switch because I could get it cheaper , I had told him the price I could get it for. I did put it in and it works every other cycle. It works every cycle when the intake pipe is disconnected from the furnace , works great then, So do I give up on this last furnace man and call Carrier. You have to understand that I'm on a fixed budget and just calling anyone is against my better judgment. I've done all this my whole life. Until they just get so complicated I don't understand it anymore, this may be one of them. The only reason I call one this time is I cut the end of my finger off with a router just a couple of days ago and I can't do much right now.
Tags
furnace carrier
Carrier Weathermaker 9200 Codes 34/14 have ignition Hawxter HVAC 9 12-31-2011 03:02 PM
CArrier WeatherMaker 9200 Code 31 jhartmann1981 HVAC 12 12-17-2010 08:04 AM
Carrier Error Code 33 russell124 HVAC 4 12-04-2010 07:19 PM
code 31 Carrier 58MXA Mr. Break It HVAC 1 01-02-2008 10:24 AM
Carrier code 31 on 58MXA (WeatherMaker 9000?) SteveAnnArbor HVAC 7 11-05-2007 06:53 PM
